Group: DynoMotion Message: 12141 From: embraced338 Date: 8/22/2015
Subject: Relative movement in KMotionCNC
Hi all,
I've got a touch plate I'm using for Z height probing, and am having some difficulty understanding how to execute relative movements in KMotionCNC to use this effectively.
What I would like to do is this:
  • Jog Z axis down slowly until the input is high
  • Once input is high, set the KMotionCNC DRO (relative or G54) to the probe height (47.5mm)
  • Move Z axis up some arbitrary amount so I can retrieve the probe
I have this code working, albeit it does not set the DRO height or move the Z axis positive.
//probing routine for DT-02 touch probe
EnableAxis(2);
Jog(2,-2000);             // jog Z axis slowly negative
    while (!ReadBit(1031)) ;  // loop until IO bit goes high
    Jog(2,0); // stop
    while (!CheckDone(2)) ; // loop until motion completes
DisableAxis(2); // disable the axis
// insert Z offset code here
    EnableAxis(2);
// insert relative move here
Some help filling these blanks would help.
Lindsay
Group: DynoMotion Message: 12142 From: TK Date: 8/22/2015
Subject: Re: Relative movement in KMotionCNC
Hi Lindsay,
See the example:
\C Programs\KFLOPtoPCCmdExamples.c
Specifically the SET_Z command.
    DoPCFloat(PC_COMM_SET_Z,1.25);
There shouldn't be any need to enable/disable the axis.
You can do a relative move with something like a MoveRel(2,1000.0);
On Aug 22, 2015, at 7:53 PM, embraced338@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi all,
EnableAxis(2);
    Jog(2,0); // stop
    EnableAxis(2);
Lindsay
